heavy clunking
Old Feb 11, 2016 | 10:43 PM
systems's Avatar
systems is on a distinguished road
Default heavy clunking
I have a 97 bravada. About a week ago my power brakes didn't work and the ABS system light went on. I did have a few glitches previously but no light staying on. Then today went and got better used tires for the front. As leaving the tire shop something didn't feel right. in about 6 blocks it started making noise up front. I pulled over and decided to shut off engine and start out again. The noise stopped but still didn't feel right (thru steering wheel). Went about the same distance and the noise return but seemed to be causing power drag when turning a corner directly after. Pulled into parking lot and did a backup with abrupt braking (checking for brake hangup). No issue noticed, so continued down the highway with it back to feeling funny only. Went maybe 1/4 mile and the clunking and drag (obvious) returned and got worse before I could get into another lot. Now it was noisy at slow speeds and could feel drag also. Nothing cleared it and I parked it and jacked up each front wheel and check for brake and bearing and ok. Still parked there. Would appreciate any input for my next step(s).
Old Feb 11, 2016 | 11:40 PM
odat's Avatar
prob your new to you front tires and the rear tires are different diameters putting the drive train a bind
99blazernky
Feb 14, 2010 10:45 PM
deck101
Jan 8, 2010 07:08 AM
infamous
Jan 7, 2007 04:18 AM
shitbox
Aug 23, 2005 11:35 AM
blazzinblazer1998
Feb 16, 2005 04:41 AM
