Manual swap help/info
Old Feb 9, 2016 | 06:38 PM
Rising_Skeet's Avatar
Rising_Skeet is on a distinguished road
Default Manual swap help/info
Hey everyone, I've made quite a few posts about my Blazer however this one is at the top of my list currently. I have a 95 Blazer 4x4 and want to do a manual swap. I know the transmission should be a NV3500, now I need to know where i can get all the parts, i.e clutch, slave, pedel, crossmember and drive shaft to do this swap or if there is a cheaper swap. I really miss driving a stick. Thank you in advance.
I've also read something about a T56 swap but is that even for a 4x4?
Old Feb 10, 2016 | 04:53 PM
Lotta work. Probably looking at wire harnesses, dash brackets, PCM reprogram or one from the donor vehicle, etc, etc. Boneyard would be the place to start looking.
Old Feb 11, 2016 | 06:36 PM
Do you recommend doing the B&M shift kit instead?
Old Feb 11, 2016 | 07:15 PM
If you're looking for shift points to be a little more "crisp", upgrading to a Corvette servo might be what you're looking for: https://blazerforum.com/forum/engine...20/#post646299
Old Feb 12, 2016 | 09:45 AM
Thank you
old skool luvr
Nov 28, 2009 10:18 PM
'87Blazer
Oct 26, 2009 01:39 PM
Traxxas14
Aug 23, 2009 10:11 AM
midnightmekanik
Jul 5, 2009 03:33 PM
craig972
Mar 18, 2008 11:48 AM
