heavy coolent leakage
Old Dec 26, 2008 | 11:25 AM
antweber29's Avatar
antweber29 is an unknown quantity at this point
Default heavy coolent leakage
i have a 96 4 door 4x4 4.3L v6 vortex blazer and have a bad coolant leak. the leak is on the top of the motor on the drivers side twords the front of the motor. i went to get a bottle of bars leak to try a quick fix. at the time i couldent find the leak. befor i bought it i asked to use there test gauge. hooked it up i pump it to about 15 lbs and could actuly see the leak. it was spouting up from right behind the a.c pump. it dosent **** out hard enough to acutly see it spouting up when its running. but it leaks a good enough to realy **** you off an **** up ur drive way.it might not hade very much anti freez in it the past week and it did get to like zero degrees maby 1-2 days this week if that tells you anything. please help i have very low funds this ression is kickin my ***. thanks' ant
Old Dec 26, 2008 | 11:38 AM
rriddle3's Avatar
Default RE: heavy coolent leakage
Sounds like an intake gasket leak. Use 'search' and there are plenty of posts regarding the repair procedure.
Old Dec 26, 2008 | 10:10 PM
antweber29's Avatar
is that the only thing it could be??
Old Dec 26, 2008 | 10:12 PM
rriddle3's Avatar
No, but based on your description (and without having a picture of it to look at), I would say it is the most likely. If you could post a good picture of the leak, it would help.
racsan
Tires and Wheels
34
Apr 7, 2015 04:41 AM
yarinzim
18
Apr 3, 2011 02:40 PM
bigmick
Sep 1, 2009 08:37 PM
RyanHowell
Sep 1, 2009 02:05 AM
gmbwrenchn
Apr 20, 2009 07:06 PM
