Help tranny problem?
Old May 30, 2009 | 01:38 PM
96chevblazer's Avatar
Default Help tranny problem?
Well on my 97 with only 67k on her is having some problems, I just got back from a 40 mile drive, and when i got almost got back to my house (about 100 yards away from my driveway) I have no take off, When i hit the gas you hear to motor reving up but there is a very slow take off. I cant even make up a little hill right now. But in reverse it seems fine. Any ideas what may be the problem? Thanks, Kane
*edit*
I have tried searching but havent found nothing like this, from a dead take off
Old May 30, 2009 | 01:59 PM
Ok now once i let it sit for a half hour its good its good as new it think it needs some more tranny fluid!
Old Jun 1, 2009 | 07:17 AM
Fluid level is very important. Check it with the transmission warm, engine running, located on a flat level surface.
Old Jun 1, 2009 | 02:15 PM
I did and it was low, we took it to the shop toady and had the fluids flushed and a new filter installed
Old Jun 1, 2009 | 02:27 PM
liftmys10's Avatar
liftmys10 is an unknown quantity at this point
Time to replace the valve body. You might want to go with TransGo and improve your shifting while you're at it by changing the servos.
Old Jun 1, 2009 | 03:02 PM
Nope that wasnt the problem, it turns out where i plugged my CB radio into drew too much power from the what ever is electric in the tranny, so it didnt it to work right, the man who was working on it very impressed that a teenager even had a CB in their truck, rewired it and grounded it inside the dash and drew power from a better spot. So problem solved!
ski.dive
Feb 7, 2014 05:18 AM
scott240
24
Mar 27, 2011 03:13 PM
bouser
Dec 10, 2009 11:46 PM
swartzy
Apr 28, 2006 10:32 PM
nine5blazer
Oct 18, 2005 05:19 AM
