Hot water quick connect manifold hole stripped
Old Oct 14, 2014 | 03:42 AM
InsanePyro's Avatar
InsanePyro is on a distinguished road
Default Hot water quick connect manifold hole stripped
First off this is on a '93 TBI 350. My blazer is no longer in this world unfortunately but you guys are a good source of info so I figured I'd ask.
I just did the intake gaskets on my '93 Suburban and was going to put the quick connect fitting back into the manifold. Turns out the threads are stripped. Dunno how it happened but it needs to be fixed. Any ideas on how I can do this without doing the job I just did all over again? I was hoping I could maybe just chase the threads as the bottom half of the threads still seem to be there its towards the top they were sheered away.
Thanks!
Old Oct 14, 2014 | 04:17 PM
rexazz2's Avatar
often the cheap white metal connector kind of disintegrates
Napa sells a kit with the proper thread chaser PIPE thread tap KIT #77-4029
It includes a easy out to remove left over connector , drill bit to clean up the hole and the tap
Same as this one
Napa 3pc Heater Hose Coupler Repair KIT 77 4029 USA | eBay
Old Oct 15, 2014 | 05:35 AM
InsanePyro's Avatar
Is it safe to drive with the hole plugged?
Old Oct 15, 2014 | 06:32 AM
Yes, but you will also need to plug the port that the other heater core hose hooks into.
Old Oct 17, 2014 | 09:11 AM
InsanePyro's Avatar
Yea I did that. I'm just trying to figure out why I lost all oil pressure on the way home. Wanted to rule this out
porkfriedrice
Sep 27, 2024 01:08 AM
WBFAir
Sep 14, 2014 06:50 PM
bearsfaninwisc
Jan 7, 2012 08:32 AM
Jonboy
Jun 7, 2010 06:24 AM
broke33
Mar 18, 2007 08:03 PM
