how do you pull heavy horsevan or trailer
Old Apr 27, 2011 | 09:41 AM
Supercity's Avatar
Supercity is on a distinguished road
Default how do you pull heavy horsevan or trailer
with a blazer, how do you pull heavy horsevan or trailer, 4X4, 4X2 or Auto 4X4 ?
I ask you this question, because last week end I've pulled a horsevan with 4X4 auto mode and my car had difficulties tu run just like it can't easily move from 4x2 to 4x4 every time. the car was shaked.
regards.
supercity
Old Apr 27, 2011 | 10:31 AM
chris015's Avatar
4x2, overdrive off. At least thats how i do it.
Old Apr 27, 2011 | 12:32 PM
Supercity's Avatar
Hello
Thanks
I have a 4X4 blazer
What do you mean by overdrive off
Regards
Supercity
Old Apr 27, 2011 | 01:32 PM
chris015's Avatar
run it in 2 wheel drive (4x4 off) that way it does not have to use extra power to turn the front tires. I THINK your blazer has the options "Park, Reverse, Neutral ,(D), Drive, 2, 1"
When you change gears,you want it to be in "Drive/D" and not in (D). When its in (D) the transmission works harder with heavy loads.
Old Apr 27, 2011 | 02:11 PM
Supercity's Avatar
my blazer has the options "Park, Reverse, Neutral ,(D), 3, 2, 1".
So it is better to change manualy the 3 drives and to stay in 3 when it is possible on the road is that right ?
Old Apr 27, 2011 | 02:45 PM
zr2dan's Avatar
zr2dan is on a distinguished road
yep 3rd gear for towing
Old Apr 27, 2011 | 02:59 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
yea, overdrive componets make the output shaft on the tranny spin faster then the engine is spinning, to save gas. These componets are not very stong for heavy loads like a trailer because your transmission shifts into overdrive depending on vehicle speed, engine load, throttle position and a few other factors, with added weight to the vehicle, the transmission will get confused and be constantly shifting in and out of overdrive at higher speeds. so stay in 3rd gear which is a 1:1 ratio, you will use more gas at higher speeds but it will prolong the life of your tranny, especially the overdrive gear / clutches.
Leave it in 2 wheel while towing, that is unless your rear tires are spinning due to the heavy load, then switch it to 4X4 to get unstuck then put it back in 2 wheel once you get going. That is if your twing in snow/ice/mud.
Old Apr 27, 2011 | 07:04 PM
4x4blazerguy's Avatar
I use an 86 F250 4x4 to pull heavy loads. For medium heavy I use our Jeep Grand Cherokee Limited 5.9.
I pulled one time with my Blazer & burned the tranny fluid black & it was so hot it was blowing out the vent tube.
Old Apr 27, 2011 | 09:47 PM
nineTnine's Avatar
nineTnine is on a distinguished road
I thought the Grand Cherokee 5.9 Limited wasn't supposed to tow anything, that's what the local Chrysler dealer told me when I was thinking about buying a 1 owner white one
Old Apr 28, 2011 | 02:17 AM
Supercity's Avatar
Many thanks to all of you.
I will do that.
Regards.
Supercity
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
chris015
Apr 20, 2012 03:47 PM
chris015
Jun 2, 2011 05:36 PM
hillbillyinOhio
Sep 11, 2006 10:42 PM
