how do you remove the top intake?
can any one help me out I need to remove the top intake on my 93 4.3 cpi. I removed all the bolts but it stuck in place, is there a way to just pop it off? I need to replace to spider injectors.
[IMG]local://upfiles/8526/D310B637DA664824BBDE23854E24AE0C.jpg[/IMG]
did you get the bolts in the back under the distributor?? if so, then it is probably just on with a gasket.two ways will prob work. put a small block of wood on the side of the intake and gently smack with a mallet, should pop, or being even more careful, pry it up with a small screwdriver. but option 1 should work fine.
blazinNdCHEVy
Jul 14, 2012 12:36 AM
dokkenette
Feb 19, 2010 05:10 PM
