i want to do a motor swap.
Old Apr 9, 2008 | 12:41 PM
gatnact's Avatar
gatnact is an unknown quantity at this point
Default i want to do a motor swap.
I have a 2001 LS w/ 4.3L v6. I wanted to put another more powerful v6 preferably carbureted or a v8 carbureted and add a super charger down the road. I do not want to do this to race, just want more go fast with easy mod. I am also looking for a drop kit and want to go as low as I can get it. If anybody can help me out or point me in the right direction that would be great, this will be my first time doing this my self. I have done this kind of stuff with other experienced mechanics so I will need lots of instruction and do's and don’ts.
Old Apr 9, 2008 | 03:14 PM
Default RE: i want to do a motor swap.
Depending on your location, moving to a carb'd vehicle may cause you to fail inspections. Aside from that, if you are set on a motor swap, then a v8 is probably going to be the cheapest thing to do. If you want to work on the motor you have, you can do a custom turbo kit or a centrifugal blower setup...
Old Apr 9, 2008 | 06:39 PM
gatnact's Avatar
I do want to work on the current motor but there is water in my oil and oil in my water and I have a small water leak some where. I dont want to jack with it to much, I think I just need to find me a new motor and work on it.
Old Apr 10, 2008 | 01:47 PM
blazin97's Avatar
blazin97 is on a distinguished road
Sorry but it sounds like you need head gaskets with oil in your water and vic versa.
350 is a simple swap(my brother is doing it right now(95_4door)).
On to the drop you can do a 4/5 drop with a notch or 4/4 with no notch.
shawtydee03
Apr 28, 2012 05:47 PM
burners
Apr 17, 2011 07:26 AM
mmatters88blazer
Aug 16, 2009 12:00 AM
rob1621
Feb 29, 2008 08:15 PM
DetroitMuscle
Dec 16, 2007 02:58 PM
