idle. problem
Old Feb 13, 2008 | 05:11 PM
Joetrillhours's Avatar
Joetrillhours is an unknown quantity at this point
Default idle. problem
How do I find the choke on a 86 chevy blazer fuel injected
Old Feb 13, 2008 | 06:58 PM
Default RE: idle. problem
So I can assume that your OTHER PROBLEM is fixed and it is now not idling properly?
Anyway, there is no choke in the conventional sense. There were two different types of early fuel evaporation (EFE) systems used. So you have either a heating element located under the throttle body to heat the incoming air charge or there is a vacuum actuated valve in the exhaust pipe just after the exhaust manifold. The valve in the exhaust pipe is controlled by a vacuum solenoid.
Old Feb 17, 2008 | 01:53 AM
well i got another question. i got the first thing fixed. but i started up the car and the idle was way high. i had to turn the car off before it blew the motor. how do i lower the idle.
Old Feb 17, 2008 | 07:59 AM
Probably have a vacuum leak. A rather large vacuum leak from the sounds of it.. The throttlebody base gasket is known to leak on these motors. Did you install a new one?
Old Feb 21, 2008 | 06:24 AM
no i didnt install a new one on it yet.
i have been lookin for new engines and trans for the car. and let them install it.
blazer chris
Dec 8, 2011 09:56 AM
UnknownFish
22
Nov 14, 2011 07:40 AM
Chevrolet.Love
Aug 19, 2011 09:05 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
Daytripper540
Mar 29, 2007 03:54 PM
