I'm about to push this car off of a cliff... any help would be greatly appreciated!
Old Sep 8, 2016 | 11:01 AM
  #21
stokedstephen's Avatar
stokedstephen is on a distinguished road
I checked the wiring and it all looked good before it started working, which was really weird. I guess there could be a control/signal wire that is shorted. I am still confused with it, because It wouldn't work at all. I'm pretty sure that it uses the resistor for the first 3 speeds, and reroutes through the relay for full speed and now it all works... so I just don't see how it could be shorted.
Old Sep 9, 2016 | 02:21 PM
  #22
Does anyone have a wiring diagram, or know where that circuit grounds?
Old Sep 13, 2016 | 09:45 AM
  #23
LesMyer's Avatar
Which RPO? C40, C60 or C68? Refer to sticker inside of glove box. I will have it for 2001. Probably the same if RPO matches.
Old Sep 13, 2016 | 11:29 AM
  #24
It is C60 (HVAC system, air conditioner FRT man controls)
Old Sep 13, 2016 | 12:23 PM
  #25
LesMyer's Avatar
here you go. this is for C60 but 2001
Attached Thumbnails I'm about to push this car off of a cliff... any help would be greatly appreciated!-89332463_zpsfo8bdprh.gif
Old Sep 14, 2016 | 06:21 AM
  #26
samtratom3's Avatar
samtratom3 is on a distinguished road
something as simple as a bad fuse? something has a small break and going over the bump, allowed the break to come back together.
Old Sep 26, 2016 | 07:26 PM
  #27
Alright, the problem is now resolved. It had a bad ground. After fixing that it is working great all the time! I should have started by checking the wiring closer. Lesson learned.
Thanks everyone for your help! Problems all solved.
WMWilson87K5
Sep 21, 2012 01:14 AM
curtnastyy
Apr 19, 2011 11:53 AM
BlazerPunisher
Mar 23, 2009 05:47 PM
2drblazer
Apr 18, 2008 08:37 PM
bigredchevyblazer
Suspension Tech
Aug 29, 2005 03:26 PM
