I'm relieved yet apprehensive
Old Jan 16, 2008 | 06:26 PM
Coldspot's Avatar
Coldspot is an unknown quantity at this point
Default I'm relieved yet apprehensive
I had the problem with the SES for "coolant below thermostat temp" and had a low reading temp gauge in the instrument cluster so I changed the thermostat and lo and behold the temp on the dash gauge is reading about 3-4 ticks higher and I noticed that the blazer is shifting better and what appears to be less often. During the thermostat change I disconnected the battery for around 40 minutes but when I put it back and fired up the blazer the SES was still on. I figured to do the PCT this comingweekend as the next possible fix. Well today after about 3 days and around 100 miles after the thermostat change(is one of those significant??) the SES goes out. It still shows up when I turn the key on so I know the light is good. What's the deal, did it just heal itself or can I expect this to rear its ugly head again? Any information would be appreciated.
Thanks
Old Jan 16, 2008 | 06:37 PM
Default RE: I'm relieved yet apprehensive
Not all codes are reset with a battery disconnect. You basically put it through a drive cycle which cleared the codes.
Old Jan 16, 2008 | 07:13 PM
Coldspot's Avatar
Thanks swartllk guess I won't be waiting to the shoe to drop.
Old Jan 16, 2008 | 09:31 PM
Hanr3's Avatar
Glad to hear you got it fixed.
Old Jan 17, 2008 | 02:55 AM
thegr81's Avatar
Glad to hear you got it fixed and that it wont rear its ugly head again!!!
drperry
Jul 18, 2007 08:22 AM
davtak
Jul 14, 2007 11:36 PM
Loud_01_Blazer
Mar 21, 2007 02:39 AM
miso
13
Jan 2, 2007 10:20 AM
jagblazer01
Mar 9, 2006 09:56 PM
