installing lines on the trans
Old Aug 12, 2013 | 04:04 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question installing lines on the trans
Hey everyone I have run into a snag trying to install the transmission lines on my 4L60e.On the side of the trans the holes have threads and so do the ends of the lines.I have read that these use a specialy quick release connection but mine doesnt seem to have them.So I started trying to thread the lines into the holes but cant get them to start for nothing.Are there brass fittings that screw into the side of the trans that the lines are supposed to screw in?If so what size are they?Thanks
Aaron
Old Aug 13, 2013 | 08:17 PM
Can anyone please help I need to get this thing together
Old Aug 14, 2013 | 07:05 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
the quick connect fitting is just a little clip seen here > Cooler Line Fitting Retaining C Clips 4L60E 4L65E 4L70E 4L80E 4T65E | eBay
It holds the line into the fitting, it would be increadibly hard to thread the line into the trans with the fitting still on the line.
Old Aug 14, 2013 | 08:33 AM
newguy's Avatar
I believe you put the nut in without the line attached, clip in the nut. Then the line with some pressure just snaps in past the clip. Someone correct me if I`m wrong
Old Aug 14, 2013 | 08:56 AM
Question
Gosh its been so long since I had this thing back in I havent a clue of whats going on.I know I had to cut my lines which I planned on splicing back together with compression fittings.I wonder if Im using the wrong end of the lines to put in the trans ,I`ll have to check that later today.If this is the case some how the other half of my lines that connect into the trans have got lost and Im either going to have to make new ones or get some old ones off another vehichle from a bone yard.Does anyone have a pic of what the fitting on the front of the line looks like?
Newguy I found a pic of the connector you are talking about and you are correct.Conclusion Im missing the front part of the lines.Maybe they are around here somewhere,I hope so.
Old Aug 14, 2013 | 02:48 PM
Question
Ok guys I got how to connect the lines figured out,now I have another problem.
I dont remember how these lines were routed underneith.Anyone have any pics of the underside?
Old Aug 14, 2013 | 10:51 PM
they route under the motor mount and starter. I'll try to get pics later. I just ran them on my v8 project so i can have a trans cooler
Old Aug 15, 2013 | 09:36 AM
I would appreciate it alot.
kerander
Sep 29, 2011 05:24 PM
ComputerNerdBD
Jan 30, 2011 01:13 PM
bigrig1186
Headers, Intake, & Exhaust
Oct 8, 2009 12:12 AM
95blazer8620
Apr 6, 2007 04:16 PM
