intake manifold help
Old Mar 10, 2008 | 09:30 AM
mab's Avatar
mab
mab is an unknown quantity at this point
Default intake manifold help
Put new im gaskets in this weekend, the job was done last year by a shop The sealant seal at the right rear manifold where the manifold meets the block was pooring oil out. I believe what happens is that auto repair shops do a good orverall job, but after the work is done oil is put in the engine right after the work, the silicone dosen't have a chance to cure, and is no match for hot oil, thus the leak!! I also made two alignment pins from bolts that are cut to 1-5/8 inches, with a slot cut in the top to accept a screw driver. I put a small amout of elect tape around the top of the boltswhere the manifold will slip over. I put the alignment bolts in the # 1 and 2 Torque sequence locations for the manifold with about 3/4 of a inch sticking out. when you are ready to install the manifold,it drops right in to place, with no worry of displaceing the silicone sealant, simply remove the align bolts and torque to specs! Hope this helps! Mike
Old Mar 10, 2008 | 10:20 AM
Default RE: intake manifold help
The alignment bolts are a good idea for anyone doing this repair. And you are absolutely correct on the sealant at the front and back of the block needing to setup. You should always follow the sealant manufacturers recommended skin & cure times.
If an oil leak were to occur at this location, it should not be a pressurized oil leak but rather just a weeping leak from the oil being splashed around in the lifter valley. If it were a pressurized oil leak, I would suspect the oil pressure sending unit supply tube.
Good advice none the less!
Old Mar 10, 2008 | 11:03 AM
mab's Avatar
mab
Ilooked at t,he oil send unit, bone dry after 90,000 The old "if it ain't broke!" The engine only dripped oil alot after a long highway trip which goes along whith what your saying! mike
s10machine
Nov 15, 2011 02:41 PM
kermit1112
20
Jan 21, 2010 11:20 AM
jspafford
May 27, 2009 09:03 AM
cRob2010
May 11, 2009 11:03 PM
polecat
Mar 29, 2008 07:45 PM
