intakes
Old Oct 29, 2008 | 01:43 PM
hazzman52's Avatar
hazzman52 is an unknown quantity at this point
Default intakes
i havetwo 4.3s onewith throttle body and another with cpi can i swap the intakes from motor to motor and will it work?
Old Oct 29, 2008 | 02:01 PM
Default RE: intakes
If you are talking about the intake manifold itself (what mounts to the cylinder heads)... They should physically bolt up, but the fuel systems and engine controls are quite a bit different between the two models. A TBI vehicle runs off of a low pressure fuel system (8-10psi) while a CPI vehicle runs off of a high pressure fuel system (50-60psi). Not only would you need to swap out the computer, wiring harnesses, etc, but you would also have to swap the fuel pump and the fuel lines themselves.
Old Oct 29, 2008 | 02:15 PM
hazzman52's Avatar
Default RE: intakes
yeah the manifold sorry for the confusion. i have a 93blazer that has a blown cpi motor. i have a spare motor with tbithat runs i was going to put the good motor in and take the cpi off the blown motor and put it the the good one with the tbi this will work am i correct?? i appreciate the help
Old Oct 29, 2008 | 02:25 PM
Default RE: intakes
Yes, it should work. There were various changes in the block through the years. Check out THIS ARTICLE which details these changes.
Old Oct 29, 2008 | 02:29 PM
hazzman52's Avatar
Default RE: intakes
THANKS FOR THE HELP MAN BY THE WAY ANY IDEA HOW MUCH TO CHIP THE COMPUTER?
Old Oct 29, 2008 | 07:49 PM
Hanr3's Avatar
Default RE: intakes
It'll work.
I put a '85 carb motor that had a TBI unit on it into a '93 with a CPI unit.
http://chevytruckworld.tenmagazines....mp;album=18998
A few pics of the process.
NOTE: the '85 4.3 came from a full size truck and has a two piece rear main seal. Since the 4.3 with a two piece rear main seal was never offered in a S10, let alone a 4x4 S10 the factory never made a oil pan for my situation. I had to fab one up myself. you wont have the oil pan problem. I added the note so you dont get confused and stress ofver the oil pan issue I ran into.
Jimmysls98
Engine & Internal
14
Feb 6, 2007 10:18 PM
Sean Pedro
Headers, Intake, & Exhaust
Jan 8, 2007 12:46 AM
TheGuardian08
Dec 29, 2006 12:52 AM
chevblazer02
Dec 27, 2006 03:44 PM
blaz3r
Oct 22, 2005 09:00 PM
