key locked in in ignition after heater core fix!
Old Jun 29, 2013 | 12:40 PM
50lb_cat's Avatar
Default key locked in in ignition after heater core fix!
My neighbor has a 95 4x4 blazer and the heater core went out, we got that replaced without an issue. He went to fire it up and the key is stuck in the ignition. I checked under the column to make sure the linkage for the shifter didnt come loose, its ok. Now in out of ideas. I think its to big of a coincidence that the cylinder went out at the same time. Its a column shifter. Any ideas?
Old Jun 29, 2013 | 03:13 PM
Twip's Avatar
did you fix it yourselves or did you take it to a shop?
did you try wiggling the column shifter to see if its just because it has some slop in it?
Old Jun 29, 2013 | 07:41 PM
50lb_cat's Avatar
We fixed the heater core ourselves and tried wiggling the wheel and the shifter. Everything went great until now lol
Old Jun 29, 2013 | 07:59 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
I'll bet its a power issue g etting to the electronic ignition switch portion that releases the key
Old Jun 29, 2013 | 08:36 PM
50lb_cat's Avatar
Thats what i was afraid of, i made sure the tranny was all the way in park. Any ideas where to start?
Old Jun 30, 2013 | 08:48 PM
50lb_cat's Avatar
Just a quick update, we started rechecking all of the electrical connections and wires, so far so good, any other ideas would be greatly appreciated!
Old Dec 19, 2013 | 09:47 AM
Irocz327's Avatar
Irocz327 will become famous soon enough
I use to have to jumpstart the bravada if it sat to long and the battery drained. Id have to jump it then it'd be fine.
Hey did you get a roof basket? I seen a Jimmy running around by walmart last week or so that looked like your with a rack & black rims. BTW the new rims look sick!
Old Jan 28, 2017 | 02:55 AM
iamchevyman5's Avatar
iamchevyman5 is an unknown quantity at this point
I second what these guys said. Check the voltage in the battery or just try to start the car. On these cars, when the battery dies with the key in the ignition, the key gets locked in.
Old Oct 3, 2017 | 03:40 PM
Dunningb21's Avatar
Dunningb21 is on a distinguished road
This is EXACTLY what I'm dealing with right now!! I replaced the heater core, put it all back together and it started. Then put a few more screws in and went to start it and key won't turn, wheel locked, shifter locked... I don't know what the heck it is! Tried jiggling the wheel, jiggling the shifter, tapping on the key with a wrench while in the ignition... I'm at a loss.
Blake726
Jan 3, 2015 07:00 PM
Scarakus
Dec 20, 2012 04:27 PM
Chic_Bowdrie
Mar 12, 2012 03:30 PM
rdlyn
Engine & Internal
May 7, 2010 05:23 AM
shadwell
Dec 3, 2007 01:09 PM
