Kickdown cable
Old Jul 19, 2018 | 09:26 AM
Gaberoberson's Avatar
Gaberoberson is on a distinguished road
Could i get just a new throttle lever? How much is a new throttle body?
Old Jul 19, 2018 | 10:14 AM
Originally Posted by Lesmyer
Here's a photo of a new throttle body for the 1991. Matches the 1989 s10 in my last post and is completely different from the throttle linkage in your photo. Sorry but it looks like you've got a bubba engine swap! You might be able to put the correct throttle body on your manifold and hook up the cables, but I would proceed carefully.
p.s. a 700R4 trans will not be long for this world without a proper TV cable adjustment. This is a known issue with them.
do you think i could make the new tv cable i ordered work right on the throttle body i have?
Old Jul 19, 2018 | 03:00 PM
Transman304's Avatar
What issues are you having with the transmission? It won’t last very long without the TV cable hooked up and adjusted correctly. Not a kick down cable. That is a line pressure cable to raise and lower the transmission pressure as required. You will definitely lose 3rd and 4th gears in short order. That geometry doesn’t look like it will work properly. Good luck!
Old Jul 19, 2018 | 03:13 PM
it takes a long time for it to shift into second gear and when it does it has a hard punch to it. But 2nd to 3rd and 3rd to 4th is fine. I thought the tv cable and kickdown where the same thing. Well either way that tv cable needs to be adjusted. I hope thats the problem with the 1st gear shifting problem. And i dont have money to buy a new throttle body. I just ordered a new tv cable, and hoping i can make it work on what i have. And hopefully the transmission doesnt get messed up till i can afford a new throttle body if thats what i need.
Old Jul 19, 2018 | 03:14 PM
thanks for the responce.
Old Jul 19, 2018 | 03:54 PM
The long shift is from the cable being on the tight side. That is not a bad thing to help preserve the transmission. Just be sure to get it adjusted correctly or you will kill the transmission in short order. YouTube has videos of how to adjust the cable.
Old Jul 20, 2018 | 09:42 AM
LesMyer's Avatar
Throttle lever is part of the throttle body. I would worry about brackets and other things being wrong as well. Better to compare at a junkyard on a vehicle that has everything you want intact, before spending money on the problem. I would start by determining what exactly you have........ https://www.autozone.com/repairguide...00c1528006c017#
Old Jul 20, 2018 | 09:44 AM
LesMyer's Avatar
I don't see where or how you are going to hook it up.
jimhaebe
Aug 5, 2017 03:34 PM
Wincanton
Dec 6, 2015 04:24 PM
Straka88
Dec 6, 2010 08:07 AM
latinoNJ
Jun 21, 2010 03:38 PM
rdhack
Feb 17, 2009 08:46 PM
