Lifter Specs
Old May 5, 2011 | 11:15 PM
streblo's Avatar
Default Lifter Specs
Anyone know the specs for adjusting the lifters?. Getting some knocking / ticking in the lower gears in high rpms.......Towed the trailer and it was fighting between 4th and 3rd gear and SUCKED back that gas....through one of those big straws for a slurpee you get from macs.......Anyways especially in low speeds, low gears high rpms speeding up getting some knocking.
Second is this something i should take a look at asap? or could it wait 5-10,000 km?.........problems associated with loose lifters are poor fuel efficiency and power mainly?
Old May 5, 2011 | 11:28 PM
Rottidog's Avatar
We have hydraulic lifters so unless 1 collapsed (which is rare) there shouldn't be any adjustments needed.
go to COMP Cams® - Instruction Sheet Database - Results - 9 & look at
1101-12 - Hi-Tech, Pro Magnum, Ultra Pro Magnum Roller Rocker Arms, CHEVY SB 1.5 3/8
They tell you how to adjust rocker arms for initial installation, you could go through those steps for adjusting but I don't think thats the issue.
As for waiting a while - I woudn't. Hows the oil pressure? Are you sure it's valve train noise & not knocking from high heat/pre detotnation, faulty plug/s, wires grounding out? You just ran over the vehicle lately checking things, changing oil etc, any chance something got bumped or changed?
mudnsno
Nov 15, 2009 05:38 PM
jcoop711
Aug 27, 2007 12:42 PM
Chevyguy032
Nov 26, 2006 04:26 PM
Bob E.
Mar 31, 2006 11:39 AM
glenmoore670
Feb 15, 2006 11:08 PM
