Line broke from rear of TB?
Old Dec 27, 2007 | 09:01 AM
CA's Avatar
CA
CA is an unknown quantity at this point
Default Line broke from rear of TB?
This is an 86' 2.8 EFI. On the rear of the T. body, two hoses (one above the other) emerge.
The top one one goes to the PVC, the bottom one is OPEN, the hose has broken.
Anyone know what the function of this outlet is for?
It is vaccum, and I covered the hole and noticed a little difference in the sound
of the engine running.
Thanks!
Old Dec 27, 2007 | 04:47 PM
Hanr3's Avatar
Default RE: Line broke from rear of TB?
It should go to a tee fitting an it provides vacuum to engage your front axle if this is a 4x4, and it provides vacuum to change your HVAC system controlls in the cab of the truck. You already realize the effects of the vacuum leak on the engine.
Look for the rest of the hose below the distributor between the engine and firewall.
Old Dec 27, 2007 | 08:52 PM
CA's Avatar
CA
ORIGINAL: Hanr3
Thank you! I knew someone would come through with an answer!
Old Dec 27, 2007 | 10:18 PM
Hanr3's Avatar
yopur welcome, and I hope it was the right answer.
Old Dec 29, 2007 | 04:14 PM
CA's Avatar
CA
Well, I ended up taking it to my mechanic and he said
is was just a hose that goes to the emissions canister.
Could someone take a look on your unit to confirm this?
Thanks!!!!
Old Dec 31, 2007 | 10:57 AM
CA's Avatar
CA
Could someone double check on this?
I'm a bit confucious......[&:]
fletch125
Aug 8, 2014 10:20 PM
clbychil
Jan 25, 2011 06:20 PM
BLAZED821
Feb 2, 2008 09:13 PM
kngflp
Jul 31, 2007 12:33 AM
george_k
Jul 18, 2007 09:02 AM
