little rough
Have you done anything as suggested?
I havn't had time time. Tommorow is when I plan on getting some work done.
Okay. I replaced the EGR valve. And cleaned the Throttle body.
Seems to be running a little bit better. Now I'm leaking anti-freeze though
Check your vacuum line going to the brake booster, Sounds like the reason for the hard brakes and rough idle
It stopped with the hard brake problem. Idle is a little smoother.
Still open to ideas.
Dadatone
07-26-2012 12:28 PM
nitsudredle
05-01-2012 01:18 PM
scrimbit
04-19-2009 06:09 PM
