Low oil pressure (97 Blazer/01 engine)
Old May 5, 2026 | 10:03 AM
tin's Avatar
tin
tin is on a distinguished road
Default Low oil pressure (97 Blazer/01 engine)
I swapped a 01 bravada engine into a 97 blazer and my oil pressure sits at 20 cold and slowly goes down to around 10 when it is warmed up. I bought an aftermarket oil pressure sensor and I went to check if oil was bypassing the sensor and getting on the plug, while I was doing that the plastic part disconnected from the medal thread part so it no longer works. I put 10w-40 in it and it seems to be running slightly better. I am close to changing the oil pump but I was wondering if there were any other things that I should check before then?
Old Yesterday | 03:29 PM
I've never had that particular problem but it does sound like your pressure is low.
I couldn't tell from what you wrote if you were able to confirm the actual pressure was low or not.
bransterdavis1996
Dec 8, 2022 10:57 AM
hellblazer
Oct 22, 2012 05:19 PM
punnerab
Jun 17, 2009 11:34 PM
88s10Blazer
Dec 6, 2006 02:49 PM
ivannj
Feb 13, 2006 02:58 PM
