Low Oil Pressure At Idle
Old Sep 28, 2022 | 08:33 AM
BigDaddy69's Avatar
BigDaddy69 is on a distinguished road
Default Low Oil Pressure At Idle
I bought 2000 LS Blazer that had been sitting 2-3 years. When I start oil pressure is at 20 psi. After warms up it drops to zero at idle. I changed oil and replaced oil sending unit and I am running quart of marvel mystery oil in engine. Using 5W30 Valvoline Max life oil. Was told switch to 10W30 oil.
Was told next oil change to put brake fluid in oil and let run 10 mins then change oil. Never heard of that.
Since it is 4WD how hard is it to change to high volume oil pump and change main and rod bearings with engine still in blazer?.
Old Sep 28, 2022 | 07:14 PM
GeorgeLG's Avatar
Be very careful running secret sauce in your oil because you can have profound unintended consequences in an older engine.
I would verify the oil pressure with a mechanical gauge and then try 10w30.
George
Old Sep 28, 2022 | 09:27 PM
Hess13x's Avatar
And to answer one of your other questions, you're not getting the oil pan off with the engine still in the truck.
Mods
Jun 1, 2020 03:04 PM
blazerhelp01
Feb 19, 2015 02:30 PM
punnerab
Jun 17, 2009 11:34 PM
tammikm
Nov 19, 2007 10:26 AM
88s10Blazer
Nov 6, 2007 07:57 AM
