Low Oil Pressure problem in 02' Blazer
Old Sep 16, 2012 | 12:42 PM
chris015's Avatar
Originally Posted by azul blazer
Your problem maybe your oil pressure sensor (located behind the distributor on the right side - in a horizontal position). I had a simliar problem on my 02 blazer the sensor cover cracked and leaking oil. In order to repair you have to remove the distributor. That is the only way to replace the sensor. I'm doing this repair(for the second time) at the present you - also need a oil pressure sensor socket to remove and replace the sensor. I hope this info helps.
I did mine on my 1st gen without removing the dis,and used a pair of channel locks on the sensor.
Originally Posted by xtremeblazer
Ok...I've replaced the oil sensor with a new one, however, the oil pressure still bottoms out to Zero on the gauge when the motor reaches operating temp. It does it only when I come to a complete stop. . . not only that but I have no idea on how to set the timing of the engine, the distributor was set back in, but a few degrees off so I've learned, and I don't know how to fix it nor have the money for a mechanic to fix it. On the oil problem, can it be a faulty gauge? I sure hope so, because at this time, I can't afford to pull the motor out to replace the oil pump. . .urrrgh HELP!!!
Unless you install a mechanical gauge (can be got for about 15 bucks) and check it with that,and not what the blazer is telling you,you wont know for sure what your pressure is. I cant help on the timing,as i suck at it myself. No point in buying a oil pump. Its job is to pump oil,the pressure you see is the pressure of the oil squeezing throughout the journals. if you have lots of wear on the bearings etc,pressures going to drop as there is more room for the oil to travel. Sounds like the engines tired,and its time for a rebuild or replacement.
Check pressure with a mech gauge,and post back,until then we cant really help you. if the pressure is still low,time for a motor. these 4.3's only need 6 psi for every 1000 rpm.
Good luck
04 Denny
29
Oct 1, 2021 10:24 PM
jnail
Sep 5, 2009 10:44 AM
bdenczek
Jul 22, 2009 10:47 AM
Hp1
Jun 11, 2009 08:30 PM
encryptedzion
May 17, 2009 07:19 AM
