Maf help!
Old 10-08-2009, 07:26 PM
1baddblazer's Avatar
1baddblazer is on a distinguished road
Originally Posted by swartlkk
I would concentrate on the P1100 code which you can take at face value. It means that the PCM is receiving intermittent data from the MAF sensor. This would lead me to believe there is a wiring or connection problem between the MAF sensor and the PCM.
The transmission control side of the PCM is tied quite heavily into the readings from the MAF sensor. So if the MAF sensor were giving spuratic data, it would get confused.
thanks man. i am gonna get new MAF sensor tomorrow and intake air temp sensor. then i am gonna hook it all up again and see what happens.. I was also told (GM mechanic) and maybe this is what you were telling me but the MAF can cause false trans codes to pop up but the vehicle will have real rough idle cause it was a bad MAF...Exactly what mine is doing, so wish me luck.
Old 10-11-2009, 05:53 PM
Default New MAF. Still Problems!!!
okay i got new MAF and all hooked it up, also got new intake plenum so no leaks..it idles okay, and drives fine until i get on it really hard, then falls flat on its face several times. like its about to cut off...HELP!!!!
Old 10-11-2009, 05:55 PM
Another new thread about this? It really would be best to keep it all together. Don't worry, I'll merge them back to one.
Did you trace out the wires as I had suggested previously?
Old 10-11-2009, 06:03 PM
thanks man. i will look again. i might have missed something.. i will check back and let ya know tomorrow. outta town right now
Old 10-11-2009, 06:18 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Are you Positive about the P1100 and the P0700 codes? I have been told a thousand times its Transmission codes installed from the factory, like "ghost codes"...Just wondering
Old 10-11-2009, 06:21 PM
P1100 is not a transmission code.
Old 10-11-2009, 06:42 PM
reelbroke2's Avatar
Thanks Kyle for the clarification..I also verified it here..http://www.2carpros.com/trouble_code...1100-P1199.htm
lannon_j
12-11-2012 02:13 PM
ChrisRapp
04-17-2011 02:45 PM
blazinron
01-18-2011 07:21 PM
ivannj
02-11-2006 03:00 PM
Labinnac
Engine & Internal
01-19-2006 04:28 PM
Quick Reply: Maf help!
