Manual swapping my 2wd 98 S10
Old Jan 31, 2023 | 06:55 PM
98briggs's Avatar
98briggs is on a distinguished road
Default Manual swapping my 2wd 98 S10
So I知 attempting the most intrusive thing I致e probably ever done mechanically speaking lol, I知 a bit of a novice when it comes to in depth swaps, how ever, I知 fairly versed in terms of replacing factory parts and diagnosing issues with my vehicles. With that being said, I went down to my local pick n pull, and grabbed a 5 speed I found in a 2.2 s10(same motor as my truck I figured that壇 be important lol) well now I知 sitting here wondering what other parts I値l need for the swap, I知 thinking pedals, slave cylinder(which I grabbed off of the donor truck), some sort of wiring harness for back up lights and neutral safety switch?(neglected to grab the wiring), what about the steering column, can I use my factory auto column and just remove the shifter lever? Am I going to need the manual trucks PCM, or can I just splice into my existing wiring harness? Any info or diagrams would be greatly appreciated, thank you all in advance!
Here is the transmission I purchased
Old Feb 1, 2023 | 12:22 AM
Definitely get the pedal assembly. I would also get the transmission wiring harness and the PCM. Measure the two driveshafts and see if they're the same. If the manual one is a different length, get that, too.
Your steering column will work. It will just look funny. You can also get the gauge cluster if you don't want the PRNDL indicator on there.
Really, the best way to do a swap like this is to get the whole donor vehicle, but that's kinda hard from a junkyard.
Old Feb 2, 2023 | 03:03 PM
eshaw's Avatar
I don't think it's a problem but you might want to see if there's a difference in transmission cross members too.
1985BlazerS10
Jan 26, 2021 02:45 AM
RedBear
Jul 4, 2017 09:46 PM
daytonablzr
Apr 15, 2014 07:01 PM
xgiovannix12
May 18, 2011 08:44 AM
jccuban13
May 12, 2008 03:52 PM
