Manual transfer case engages itself-Any Ideas?
Old Sep 9, 2010 | 11:19 AM
southernsteel87's Avatar
southernsteel87 is on a distinguished road
Default Manual transfer case engages itself-Any Ideas?
Every time I stop quickly (1987 K5 Blazer) I get a grinding/whining noise coming from the transmission, and no movement, it can't get into gear. I have to turn the motor off, move the lever to 4Lo, put it in park, start the motor(no more grinding), shift to neutral then back to 2WD. Not fun to do in the city. Motor mounts and tranny mounts look good.
Old Sep 9, 2010 | 11:22 AM
Your transfer case is dropping into neutral. Which transfer case do you have? Look at the tag on the back of the transfer case.
Old Sep 9, 2010 | 11:29 AM
Np-208
Old Sep 9, 2010 | 11:42 AM
You could try to adjust the linkage, but if the truck has high mileage, the pads on the shift fork inside could be worn to the point of needing replacement. I have seen a few where the pads were worn completely away and the fork was starting to wear. This required a complete replacement of the fork.
Drivetrain.com has an NP208 page that has an exploded view. They also carry the mode and range forks. I believe that the range fork is what controls the neutral shift, but you will have to open it up to see which ones are bad. Hopefully you only need the pad kit if it needs to go that far.
Old Sep 9, 2010 | 12:06 PM
Thanks for help I'm going to order that fork today, never taken apart a transfer case before , do you know if I need any special tools or can I just make do with what I can find in my garage.
Old Sep 9, 2010 | 12:12 PM
Old Sep 9, 2010 | 12:38 PM
Dude you are amazing, you saved me so much time, this is going to be a piece of cake.
Old Oct 23, 2010 | 10:23 AM
J-Adix's Avatar
J-Adix is on a distinguished road
Default Same Boat
Hey guys
My '83 is doing the same thing, I've also never rebuilt a transfer case before. I ordered a rebuild kit, and both forks (I just figured I'll replace 'em all while I'm in there), once they get here I"ll start tearing into it. Got any tips?
Josh
Flyfishen
Jun 18, 2019 11:22 AM
Muddigger86
Feb 8, 2014 09:41 AM
five04ever
Nov 13, 2009 08:03 AM
dusted800
Apr 8, 2009 09:20 PM
Railin7
Jan 29, 2008 12:50 PM
