MPG's
#21
RE: Try the shell gas
ORIGINAL: BlazerSS
thanks for voulanteering Zasder! I would do it as well, Im just a little low on fundage right now. Make sure you read the directions, as I believe when you add it to your tank of gas, you are supposed to initially add 3-5o.z. to your oil as well one time only. Keep us updated.
I'd reccomend against adding foreign substances to your engine oil unless it's needed
#22
No you add 3oz first time to your gas tank
Then for every fill up you use 2oz (since I have a 19 gallon tank) it takes 1oz for every 10 gallons
this stuff isnt going anywhere near my oil lol
#23
I suggest youread the entire article about the product, it specifically statesthat you need to "add 1o.z. ofEthos per 1 quart of oil to youroil to see maximum results".
http://www.thegassecret.com/
#24
Ok, maybe I will then
I found a 32oz bottle for 30 bucks, so here we go!
#25
ORIGINAL: Zasder
#26
I filled up my truck with BJ's gas and no problems. Truck was on empty and I had to get gas so I was driving past itand went there
#27
I found IT on EBAY... lol
#28
Nice, glad you could find IT on ebay.
#29
#30
Mpg
a friend of mine had a 2000 blazer and had a bad sensor goin to his fuel injector. this was in the summer and he was getting 11-14mpg. Gasoline quality does make a big difference just like everyone else was saying
