MY problems after 4.3L intake manifold gasket replacement?
Old Nov 16, 2009 | 08:51 AM
His truck will have the cast aluminum pan which is a bit deeper in the center section than the steel pan. Plus, you cannot move it backwards due to the mating surface on the front of the transmission bell housing like you could on the other engines.
Cutting open the filter is a good idea. It will show you if anything has gotten past the screen on the oil pickup. If something large got down into the sump though...
I use a chain pipe cutter to cut open filters:
Works GREAT!
Another idea is getting a hold of a bore scope and looking into the pan through the drain plug... I have been thinking about getting a bore scope for quite a long time.
Old Nov 16, 2009 | 09:46 AM
dunontme's Avatar
dunontme is an unknown quantity at this point
I cut the filter open and there is rag particals in it. so a rag and some of the old gasket material that the rag was catching was left in...now what?
Old Nov 16, 2009 | 10:36 AM
If the particles are in the filter, there most likely are larger pieces on the oil pump pickup. I would get yourself ready to remove the pan; either through removal of the front axle or removal of the engine. My vote is to pull the engine so you can go through everything properly.
Old Nov 16, 2009 | 07:42 PM
old skool luvr's Avatar
Originally Posted by jigger
Also if you have to take off the pan you might want to learn a second language cuz I'm sure you will run out of cuss words like old skool said! good luck
hey! i never said you'd run out of swear words. is that even possible?........
X2, 'cause you're definately gonna be going through that engine now.
Old Nov 16, 2009 | 08:01 PM
jigger's Avatar
jigger is on a distinguished road
Cool
Maybe that's just me, I speak english and a little spanish, sometimes it comes out as uninteligable jibberish. Like the bond cable on the back of the passenger side head- that:icon: was fun!
Old Nov 16, 2009 | 08:05 PM
jigger's Avatar
<P>Old skool: Maybe it's just me, I know that ground on the back of the passenger side head left me a little language challenged!</P>
Old Nov 16, 2009 | 08:57 PM
dunontme's Avatar
well thanks for the help guys I know the problem now. I'v started a new post asking for help on how to fix this here https://blazerforum.com/forum/engine-transmission-35/engine-removal-help-37031/
how do I delete this post?
Old Nov 16, 2009 | 11:35 PM
you don't deleate a post. it stays up for others to use the "search" function, if they're having something similar happen to their truck.
just be thankful that you don't have large hands-you would've been making upa whole new language!
Old Nov 17, 2009 | 01:46 AM
dunontme's Avatar
ok I'll leave it up for the next dummie to leave a rag in his engine lol
Old Nov 17, 2009 | 11:04 PM
and he/she will thank you for your thoughtfulness, bwahahahaha!
lionpaw2012
Jun 8, 2015 01:07 PM
awesomeamerican1
Dec 6, 2014 12:01 AM
jspafford
May 27, 2009 09:03 AM
ComputerNerdBD
Mar 10, 2009 09:33 AM
Exodus5
15
Feb 20, 2008 10:02 PM
