Mystery part
Old Aug 13, 2014 | 01:08 PM
Motodad117's Avatar
Motodad117 is on a distinguished road
Default Mystery part
I bought a 98 blazer from a blind mechanic... The washer fluid rez was sucking air and adding fluid killed the engine. I traced the lines and it was hooked up to this (see photo). For the life of me I can't figure it out! Can someone please identify this? Any info is appreciated!
Old Aug 13, 2014 | 01:29 PM
newguy's Avatar
Well it looks like a vacuum ;line that goes in the hole behind it in the picture. And there should be no vacuum lines attached to the washer fluid res. Electric pump
Old Aug 13, 2014 | 04:26 PM
Motodad117's Avatar
Hmm... I did pull it off for the photo. Here is one with it connected. Do u have any idea what it's supposed to be connected to?
Old Aug 13, 2014 | 04:36 PM
newguy's Avatar
Brake booster (by steering column) and other vacuum lines. The way it was it sucked window wash into your intalke. Right onto the pistons. Not good
CPLSeraphim
Jun 22, 2014 05:41 PM
jblaz
Dec 23, 2012 04:08 PM
spider21
Nov 17, 2011 06:27 PM
punx.inc
May 28, 2009 05:57 PM
garry2000blazer
Aug 13, 2007 09:25 AM
