Nasty Coolant leak
Old May 23, 2008 | 06:24 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
Default RE: Nasty Coolant leak
I just had a simular prob. was getting a small oil leak that traveled down the back of my engine
into the flywhell cover onto the starter when I found this I also found a small trail of coolant leading down to the same area. I changed my intake Manifold gasket and the Problem is solved.
The hose your asking about is it a coolant hose or Vacuum hose. Your (2) heater hoses will run from the firewall to (1) water pump (2) top of intake Front of Engine There are (2) Vacuum hoses
on the backside (1) to the Brake booster (1) into the back side of the intake Mine is a 95 so you may have a different setup
Old May 23, 2008 | 06:44 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
don't know which side the temperature sending unit is on, on the newer models but look to see if it somehow got loose. (the infamous mechaninc that worked on my truck didn't screw it in all the way)
panheadmat
Sep 10, 2010 09:42 AM
bobditts
Suspension Tech
Jul 10, 2009 08:45 PM
blazinloud
Jul 12, 2007 06:03 PM
AK8BLANK
Suspension Tech
Mar 3, 2007 07:55 PM
BigGreenMonster
Sep 12, 2006 12:17 AM
