needing some help pleaseeeeeeeeee
Old Jan 26, 2009 | 11:03 PM
daniel010's Avatar
daniel010 is an unknown quantity at this point
Default needing some help pleaseeeeeeeeee
Ok heres my prob my horn wont work my electric hatch wont pop open my dome lights when i open the truck wont work all of a sudden it was fine before...I check the fuses they were all fine there 2 bigger fuses on there one says power windows and the other is Power/ACC and i cant see if that ones fine or not when i plug it in and take it out i here a click inder the driverside dashhh..Is there somtthing im missin
Old Jan 27, 2009 | 01:12 AM
daniel010's Avatar
Default RE: needing some help pleaseeeeeeeeee
my buddy just did my heater core is there a ground wire for that somwhere if there are where is it
Old Jan 27, 2009 | 01:24 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
DUDE! Are you 11 years old? This has nothing to do with Trans or Engines! You just keep popping around here spamming the place up with repeated questions about the same problem. Alota People here have real lives outside of BF. So take a chill pill, calm down, keep the posts together (makes it easyer to figure out what has already been done/tried), and give people a chance to respond. Your not helping yourself by acting a fool. Your not the only oneexpecting a miracle!
P.S. It HELPS ALOT if you put the problem description in the subject as well!
Old Jan 27, 2009 | 01:37 AM
daniel010's Avatar
Hey dont post then on here pretty simple..I didnt even mean to post in here..Ur a idoit
Old Jan 27, 2009 | 01:49 AM
I suppose I egged you on with my first comment, but the rest was meant to be helpfull! I appologies that it came out rudely. Good luck
Skitzoape
Jul 20, 2013 11:22 AM
agreen96
Sep 23, 2010 09:59 PM
86Blazer4x4
Jun 30, 2009 08:26 AM
brosko
Feb 7, 2009 08:07 AM
daniel010
Jan 25, 2009 11:10 PM
