no 1st an overdrive gears
Old May 14, 2009 | 07:22 PM
georgia_boy79's Avatar
georgia_boy79 is on a distinguished road
Default no 1st an overdrive gears
high guys i hope you can help me out,i have a 93 chevy blazer 4x4 lt with the 4.3 v6,well here is my problem.got in one morning to go to work put it in drive an felt like the emergency brake was on,so i check but it wasn't on,pulled it down to 1st same thing so i pushed it up to 2nd an it went put wouldn't shift to third,only way was to manualy shift it,ok so i changed filter new fluid an the solenoid A,an i also went ahead and changed ther ignition switch as i read on another forum that i would cuase similar problems but nothing has changed,an i have no idea were to go next any help is greatly appreciated
Old May 14, 2009 | 08:08 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
sounds like the tranny is on its way out.
Old May 14, 2009 | 11:27 PM
Blazercrazy's Avatar
Blazercrazy is an unknown quantity at this point
Is the kick down cable for the tranmission hooked up right? or even hooked up, It won't shift if its not
Old May 15, 2009 | 06:44 AM
yea everything is hooked up right,an its no like its slipping its like it don't have the gears at all
Old May 15, 2009 | 10:52 AM
Check out this thread:
trans issue
TheBrandit
Oct 17, 2012 11:18 PM
filtalr
Sep 3, 2012 06:10 PM
James1965
Jan 16, 2012 11:32 AM
baca1985
Apr 2, 2010 10:19 AM
zionatdirt
Oct 23, 2008 03:10 PM
