no start
Old Aug 17, 2014 | 08:54 PM
johndeerezach's Avatar
johndeerezach is on a distinguished road
Default no start
i just picked up a 2000 s10 with the 4.3 for very cheap they said it got to much fuel. so i couldnt even get it to start would crank all day long but i never had it crank from just the battery it was dead so i hooked it up to my diesel. now i changed cap and rotor, plugs , wires were new, and a battery, it wouldnt start off the new battery so i jumped it, ran fine blew the cobbs out and got it warmed up. but sometimes if i shut it off it will turn very slow sometimes it would start now it will not. 12v at batt off 14 while running. so im assuming my starter is out? it will dim all of the lights while tring to turn over. thank you
Old Aug 18, 2014 | 10:27 PM
odat's Avatar
pull the starter and take it in and get it tested - my bets it's dead
Old Aug 19, 2014 | 06:10 AM
Yea that's what I was thinking I was Guna go get one today
Old Aug 20, 2014 | 08:33 PM
Well I finally got time to mess with it and I replaced starter with a k own good one and it's still doing the same thing I have a loud clicking noise now from under the hood it
Old Aug 20, 2014 | 08:37 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
Check your connections from battery to starter as well as ground. It happened like that before on a friends truck and it turned out just needed the connections cleaned.
Old Aug 21, 2014 | 01:45 AM
odat's Avatar
PO stated that it had too much fuel causing no start issue - try cranking it over by hand make sure it's not seized or in the process of seizing up - fuel might have washed by the rings and you might have lost a bearing - you might have to pull the plugs to make it easyer to turn over
ejxjohnson
Sep 10, 2010 08:21 PM
blazerJim1701
Jul 26, 2009 09:18 PM
Larhatch60y
Nov 8, 2007 01:05 AM
actionpaintball
Jul 14, 2006 07:53 PM
