No start
Old Nov 19, 2018 | 03:29 PM
Jss's Avatar
Jss
Jss is on a distinguished road
Default No start
Hello all,looking for a little help. I own a 1995 s10 2wd blazer. I drove it to work and when I went to leave, i tried to start and all I got was a thunk. I checked the starter and it was bad. Replaced the starter and engine turns by hand .when I reinstalled the cover plate under the torque converter,the engine would not turn. I removed the cover and was checking to see if converter bolts loose etc. Now the engine will not turn more than about half way. I checked all fluids etc don't see any metal in the oil and it has trans. fluid. The fluid doesn't look too burnt. Was going to pull plugs to see if getting compression. ..or try putting a camera in to see if stuck open valve ... could the flex plate broke or transmission pump broke? Truck ran great up till trying to start after work. ANY help would be appreciated.
Old Nov 19, 2018 | 07:43 PM
chevyriders's Avatar
I've heard similar stories turn out to be a broken flex plate or loose torque converter bolts binding up. I would try to listen and hear what area the thunk is coming from when it spins halfway, and try to narrow it down from there
Old Nov 19, 2018 | 09:25 PM
Jss's Avatar
Jss
thanks for the input, I will let you know what I find out
Justin Kane
Mar 18, 2017 05:30 PM
adumsted
Jul 6, 2012 09:46 AM
Toby Hanson
Dec 9, 2011 12:33 AM
brandon1029
Feb 22, 2011 05:51 PM
dahondaboy
Aug 4, 2009 09:43 AM
