No Start after fixed blown head gaskets
Old Feb 9, 2008 | 04:26 PM
chrismiller_87's Avatar
chrismiller_87 is an unknown quantity at this point
Default No Start after fixed blown head gaskets
My 1998 blazer, blew a head gasket couple months back tore engine apart. found bad head gasket replaced all gaskets from headers up. went by the book in torqueing bolts, followed sequence. When we got it together all wires connected etc.pured in new oil, antifreeze. new filters. went to start, no joy wont crank over, backfires but that is all. distributor is set right, and timing is good. running out of ideas.
Old Feb 9, 2008 | 04:31 PM
thegr81's Avatar
Default RE: No Start after fixed blown head gaskets
Is the motor getting all the essentials, fuel, air and compression?? When you got it all together did you do a compression test on it??
What about the plugs are they gaped correctly?? And as for the wires are they in there proper sequence???
Old Feb 9, 2008 | 04:45 PM
theres compression but i believe its weak ill have to get a gauge and test it. spark plugs and wires are good.
Old Feb 9, 2008 | 04:51 PM
thegr81's Avatar
Ok I would test the compression on it again and see what you get!! Another thing when you rebuilt your motor did you happen to have the heads resurfaced at all??
Old Feb 9, 2008 | 05:50 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
the dist sounds like its off to me, by having backfiring!!! Can you specify the installation procedure you did for the dist...That way we can count that out as a symptom..
By the way Happy Belated B-day!! old man lol
Old Feb 9, 2008 | 07:11 PM
thegr81's Avatar
Oh it was your birthday, dang Happy belated b-day then!!!
Old Feb 9, 2008 | 08:48 PM
88_Blaze4x4's Avatar
88_Blaze4x4 is an unknown quantity at this point
ive had it where the distributor is 180 degrees out. ive done it a couple times with the 4.3L. the engine backfires and locks up a couple times while cranking. double check make sure the 1cyl is at TDC on compression stroke then set distributor again. its a very easy mistake ive done it 3 out of 5 times while doing engine jobs.
limited edition 1
Jan 27, 2023 11:07 AM
NEW YORK BOY
Nov 13, 2012 10:05 PM
reeladdiction
Oct 8, 2011 04:02 AM
Blazer1999ls
Jul 16, 2009 12:05 AM
tesshin
Mar 3, 2007 11:16 AM
