Is this normal?
Old May 4, 2011 | 07:21 AM
TheRandom1's Avatar
Default Is this normal?
My trans doesn't seem to be shifting properly so I need some advice here guys. A little backstory, I bought this truck on Saturday for $1,600. Everything felt pretty OK although the trans seemed to slip a little bit. The fluid was filthy so I assumed that to be the cause. Then the SEL came on and told me that the 1-2 shift solenoid was bad. OK, no biggie, it's $25 bucks. So I took it to my mechanic (I don't touch trans fluid) and had the trans fluid/filter changed out, and the solenoid replaced.
Now the trans sometimes seems "better" but other times seems to either slip or just not want to shift. I'm hoping i don't have to spend another grand on a trans, so... help? I took a video, hopefully it's good enough.
Video is here: http://www.youtube.com/watch?v=pSpLSdEufNM
This is a 2000 Blazer ZR2 with 130K miles on it.
Old May 4, 2011 | 07:06 PM
TheRandom1's Avatar
Just talked to my dad who is used to my stepmoms 03 ZR2 and he says it does not feel like hers does at all. So I'm looking at a trans rebuild/replacement. A friend of mine has a guy she sends business to and he said $1,050 out the door. Is this a good price?
Also, It looks like the rear main seal may be leaking, is this something I should see if they could replace while the trans is out or does it matter?
Old May 4, 2011 | 07:17 PM
Rottidog's Avatar
Yeah that seems like it's slipping. I paid $1800 Canadian for my trans rebuild, but that's with a Mr Shift 2nd stage shift kit, corvette servo, kevlar belts etc. So $1000 should be a good deal if they do the work properly & warrenty their work.
Old May 4, 2011 | 08:00 PM
TheRandom1's Avatar
How long did it take for your trans to be rebuilt? This is my only car so I'm trying to decide if I'm going to need to budget a rental car in there too.
Old May 5, 2011 | 09:39 AM
Rottidog's Avatar
2 days dropped it off 1 morning & picked it up the next afternoon after work
Old May 5, 2011 | 09:40 AM
TheRandom1's Avatar
Hm. I'd need a rental for one day then unless they work on Saturdays.
Was yours rebuilt or did they replace it with a built up one?
Old May 5, 2011 | 08:29 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
I took about 2 hours or so to rebuild mine , but you are probably going to want to make a apointment . I don't no how things are in your area but around here that type of work is very much in demand . It costs 1649 dollars for a monster heavy duty 4x4 rebuilt transmission MonsterTrans.com might be worth checking out . They say that this transmission can handle up to 500 hp should be a worth while up grade .
Old May 5, 2011 | 08:38 PM
TheRandom1's Avatar
I talked to the guy who will be doing mine and was quite disappointed. $1,050 plus 25 or so (whatever the part actually costs) to replace the rear main seal which appears to be leaking.
The down side is it will be 3-5 days while he rebuilds. The good news is that unless I'm wrong about where the oil is spewing from, this should take care of both problems I'm having. I suppose I should make sure that's where the oil is coming from now...
Old May 5, 2011 | 09:19 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
Hello this link is for one of the best 700R4 4l60E experts around he specializes in these trans. I put one of his kits in mine and made the whole S-10 Blazer come alive. 700R4 & 4L60E Automatic transmissions specialists - ProBuilt
Old May 5, 2011 | 11:17 PM
Rottidog's Avatar
They pulled mine, completely took it apart, tanked everything (solvent cleaned) & reassembled with the upgraded parts. They said I could haul on this in any gear up to 500hp all day & not hurt it, this side of neutral drops etc lol. I do know if I'm doing 40mph & drop it into 2nd or even 1st it goes! Love compression braking in the winter.
amkonyk
18
May 30, 2009 11:32 PM
jimmyboy
Lifting Tech
Oct 29, 2007 02:12 PM
EuroGoldLS
Engine & Internal
Jun 7, 2007 11:45 PM
blazinloud
Dec 31, 2006 02:03 PM
Loud_01_Blazer
Oct 4, 2006 02:20 PM
