not chargeing
Old Dec 10, 2015 | 02:05 PM
montanablazer's Avatar
montanablazer is on a distinguished road
Default not chargeing
94 s10 blazer, new alt, starter, an battery. had then all tested tons of times.. i tested the back of the alt when running an the battery an the voltage is at 12.2v what could be the problem??
Old Dec 12, 2015 | 05:32 AM
Red Sled's Avatar
Red Sled is on a distinguished road
The alternator should be putting out 14.3 when running.
Old Dec 12, 2015 | 10:51 AM
abig84's Avatar
check the fuses in the fuse box or any fuse-able links to see if they are blown. sometimes a blown alternator will take out the fuse too.
Old Dec 13, 2015 | 01:48 AM
checked the fuses, i did find a plug under the dash, i unplugged it an noticed a wire was burnt, it is hooked to a plug that has a big orange wire, red wire, and a big purple wire, by any chance you guys knw where them wires go or what this plug end plugs into?? i dont got any wire diagrams so thats out.. the wire thats burnt is a small wire, i mean the plastic shield is gone off the wire..
Old Dec 13, 2015 | 02:49 AM
Rusty Nuts's Avatar
Good job finding that. Could you tell us in as much detail as you can where it's located, and describe the component you unplugged? Color, size, shape, everything helps. Was the burnt wire touching anything under there?
This plug has 3 wires. 2 big ones (orange and purple) and a smaller red wire that's burnt. Correct? No black wire is a clue.
Maybe you could leave it unplugged, start it up, and try everything to find out what now doesn't work. Is there something that hasn't been working or acting up before this?
Old Dec 13, 2015 | 08:03 PM
Default what are these wires??
have a charge problem found this burnt wire, runs up with a few other black wires an goes into a metal plug an then a few other black wires run out.. only 1 wire is burnt an it goes to this plug which plugs into this relay waaaaay up inside the dash an i got no idea what any of this is, what the relay is for ect
Attached Thumbnails not chargeing-dsc00243_zpshweu7lpj.jpg   not chargeing-dsc00239_zpsgqwaj0mj.jpg   not chargeing-dsc00233_zps16apnskm.jpg
Old Dec 14, 2015 | 02:05 PM
ok guys here is some pics, the plug, therelay or what ever it is, an the black wire runs to a bunch of other black wires but thats the ony burnt wire out of the bunch.. an info on what these wires are for an what that relay thing is??
Attached Thumbnails not chargeing-dsc00239_zpsgqwaj0mj.jpg   not chargeing-dsc00233_zps16apnskm.jpg   not chargeing-dsc00243_zpshweu7lpj.jpg
Chadoo951
13
Jun 30, 2010 01:59 PM
wayland
Dec 9, 2009 12:38 PM
96Ls4Dr
Oct 26, 2008 04:45 PM
Thor_449
May 26, 2008 12:00 PM
cheri_lee28
Jan 19, 2007 05:27 AM
