o2 sensor
Old Mar 9, 2010 | 09:30 AM
blackyctm's Avatar
blackyctm is on a distinguished road
Default o2 sensor
i have a 2000 blazer 4x4 4 door 4.3l and i got it like 3 or 4 months ago and when i was test driving it the check engin lite came on the dealer i got it from took it to a shop where they did a tume up and changed the o2 sensor yesterday i saarted having really bad trans problems (unrelated) but at auto zone there scan came up and said in addition to the trans codes i need an o2 sensor. im wondering if theres something causing the 02 code or my o2s to just crap out. any thoughts would be appreciated
Old Mar 9, 2010 | 11:46 AM
AJBert's Avatar
Kind of need to know the codes as that will pin point which O2 sensor(s) is/are throwing the code(s).
Old Mar 10, 2010 | 10:19 AM
Hanr3's Avatar
Generally the 02 sensors dont just die, smae with the cat. Check your fuel pressure, and more importantly look inside the upper intake, if its clean you ahve a leaking spider injector hose.
your tranny problems could be related to engine problems and might go away once the engine is fixed.
If your not a DIY, this is one area best left to the pros, take it in and have the dealer do a diagnostic test on the truck. It might cost $80-$100. But you will save that by not replaceing a bunch of parts for no reason, especially the tranny.
If you want to do the work yourself, let us know.
joey
Aug 27, 2012 06:33 PM
GM hater
Jan 9, 2010 02:32 PM
theeviltwinn
Oct 23, 2009 06:37 AM
daniel010
Feb 2, 2009 06:50 AM
Spartan66
Jul 11, 2008 02:34 PM
