OBD II diagnostic interface
Old Jul 26, 2018 | 06:56 PM
Stoggers's Avatar
Stoggers is on a distinguished road
Whichever OBD2 adaptor (not the software/app, the hardware you plug in to the OBD port) you use, it must support VPW J1850 protocol. Some do not as I have found out and they won't work on your Blazer.
This one (https://bafxpro.com/products/obdreader) does and is good value.
Old Jul 27, 2018 | 03:33 AM
Bibol's Avatar
Bibol is on a distinguished road
I'm waiting for the shipment. I'll call you when I receive the package.
Old Aug 27, 2018 | 01:13 PM
Bibol's Avatar
The reader has arrived. It works on every application. Unfortunately, it does not read ABS, drives, automatic transmission, LPG installations. Or I'm doing something wrong.: icon_steer:
Old Aug 27, 2018 | 09:00 PM
LesMyer's Avatar
So now you are connecting with the PCM, correct? If so, the interface is doing it's job. Now you need software application to communicate with PCM to do what you want. None of the phone apps you mentioned will read ABS codes. Auto trans is part of powertrain codes. LPG installations - why would it? Not sure what you mean "drives". As I said before, Car Guage Pro is the phone app that will do the most. It will read/clear ABS codes as well as re ad/clear codes for other modules on the Blazer days bus. It will not read ABS PIDs on a Blazer. Please study about OBD2 to understand the difference and I think you will then understand. What is the problem you are trying to solve?
Old Oct 27, 2018 | 07:34 PM
BravadaJunk's Avatar
BravadaJunk is on a distinguished road
Without starting a new topic maybe someone can help me. This is the first I've seen these BAFX OBDII devices.
I'm wondering if this device and the appropriate software can help diagnose TCCM issues. My first post can actually explain issues more, but I was hoping this method would allow me to send activation commands to the transfer case and help diagnose possible wiring issues. 1998 Bravada AWD
Old Oct 28, 2018 | 12:27 PM
LesMyer's Avatar
AFAIK, none of the apps using bluetooth OBD2 adapters like the BAFX will do anything more with 4WD than read and clear codes. You are asking for bidirectional control of an alternate module (TCCM) on the vehicle data bus. Some say Autoenginuity and Snap-on give a lot of these bidirectional controls, but I have no experience with them. I'm quite sure you can replace both the TCCM and the encoder motor with new for what they cost. The rest of the system just takes a digital volt/ohm meter to check out.
Old Oct 28, 2018 | 06:13 PM
Thank you. Now that I know it can't be done I'll move on and try to find a solution.
LesMyer
72
Jul 14, 2022 10:09 AM
StoZR2
Feb 15, 2019 09:34 AM
jdiding
Feb 20, 2018 10:30 AM
John925
Jul 22, 2016 07:13 AM
Tajohns34
Jun 12, 2015 04:23 AM
