Oil Cooler Lines
Old Jan 29, 2009 | 06:01 PM
BlazerSS's Avatar
BlazerSS is an unknown quantity at this point
Default Oil Cooler Lines
Is Dorman the only manufacturer that makes the Oil Cooler Lines for our trucks, or is there a better more reliable option? Part# for my app is Dorman 625-122. The leaks are now at all 4 ends and is getting worse so I will be replacing these within a month.
thanks
Old Jan 29, 2009 | 06:23 PM
rriddle3's Avatar
Default RE: Oil Cooler Lines
They're the only one I could find that shows the entire assembly (hose & metal lines), but at O'Reilly it also shows Hayden for just the hose.
Old Jan 29, 2009 | 06:46 PM
BlazerSS's Avatar
Thanks rriddle, I will look into that as an option. These lines are a pita! Also thinking about replacing the intake manifold gasket. This I know there is a make than oem. Ive seen it mentioned here, but cant find throught the search. Anyone know which gasket it is? I think they are copper....?....
Old Jan 29, 2009 | 06:47 PM
rriddle3's Avatar
Fel-Pro.
Old Jan 29, 2009 | 07:29 PM
BlazerSS's Avatar
you just beat me to it rriddle, I found it while looking through the forum.I havegot a part number for Fel-pro intake manifold gasket FPMS95817. Does this seem correct?
Old Jan 29, 2009 | 08:16 PM
rriddle3's Avatar
Looks like the one. $33.79 at rockauto.com
Old Feb 2, 2009 | 09:56 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
The new GM ones are fantastic! They're aluminum now instead of plastic! I think I paid $30.00 with my discount.
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
eng69
Jan 31, 2006 04:55 PM
zero psi
Oct 28, 2005 04:45 PM
