Oil Cooler Lines on '99 ZR-2
Old Mar 3, 2007 | 02:21 AM
bgillette78's Avatar
bgillette78 is an unknown quantity at this point
Default Oil Cooler Lines on '99 ZR-2
i noticed a big puddle of oil in my garage and did some research on it and this site helped me out alot on getting down to the problem. glad i fixed it myself instead of taking it into a shop. i went to the local auto store and only spent about $80.00 for both of the lines. the job went pretty smooth the line back to the engine block gave me the biggest headache. overall the job went well very easy and i completed the line change and oil change with in about an hour. so if there is anyone out there wondering on how hard it is to do this yourself as i was it is a very simple repair and alot less expensive to do it yourself. once again thanks guys
Old Mar 3, 2007 | 02:31 AM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Oil Cooler Lines on '99 ZR-2
Yeah those lines arn't too bad to do. I have done quite a few of them ,that is for sure!! Korey
Old Mar 3, 2007 | 01:51 PM
blazinloud's Avatar
right on, at least theirs 1 easy repair for this truck [8D]
I got the used dealership to replace mine before i bought it...so hopefully their good for another 5 years.
Old Mar 3, 2007 | 06:00 PM
blazinwoody's Avatar
blazinwoody is an unknown quantity at this point
When I was chaning my oil today I saw that my cooler lines were also leaking. Alone with my oil pan gasket and my rear main seal. I guess I'll be wrenching on it soon.
Old Mar 6, 2007 | 03:17 PM
88blackzcand95blazer's Avatar
88blackzcand95blazer is an unknown quantity at this point
bout ready to swap both the filter line and the cooler line in my 95 4x4 as well getting them both for $75 including shipping from ebay, supposibly great quality and guarented. the forward one looks easy but how hard is it to do the back one (the two lines that go to and from the engine to the oil filter)? any suggestions to make the job easier?
Old Mar 6, 2007 | 08:19 PM
i started out just using my extension with the socket on the end and that was a big headache then iused about a 12 inch extension and then used a swivel end with the socket and you can get it in to that area at an angle and it makes it much more simple. then there is a small backet that holds the lines up. that is a big headache also it just takes some time and some patience to get to that one other than that it is fairly simple.
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
eng69
Jan 31, 2006 04:55 PM
zero psi
Oct 28, 2005 04:45 PM
