Oil doesn't drain
Old Mar 28, 2010 | 10:42 AM
rick2010's Avatar
rick2010 is on a distinguished road
Default Oil doesn't drain
I have a 2001 4wd 4.3l Blazer. I changed my oil yesterday and only about 1.5 quarts drained out. I figured that I must have had a leak because the oil drain plug gasket was missing. So I added 5 quarts. I checked the dipstick and it was above the full mark. So today, I went to drain it all out again, and add in the appropriate amount, but only a few ounces drained out. I checked the oil and it is still above full. How is the oil being blocked from draining? I put a screw driver carefully in the oil drain hole and didn't feel any blockage. Any ideas/help would be greatly appreciated.
Old Mar 28, 2010 | 12:36 PM
mech cb's Avatar
mech cb is on a distinguished road
Sounds like you may have to drop your pan and see what's going on. If I were to do it, I'd keep the plug in, have the truck on the ground, and place a floor jack, or floor tranny jack to help keep it from tipping.
lazer2000
Sep 16, 2012 11:16 PM
gooder
May 4, 2008 04:10 PM
MCas86
May 11, 2006 07:40 PM
eng69
Feb 13, 2006 03:08 AM
2001Blazer4x4
Mar 2, 2005 10:45 PM
