Oil leak !!! New to blazers
Old Mar 7, 2018 | 01:16 PM
Stonemadeink's Avatar
Stonemadeink is on a distinguished road
Default Oil leak !!! New to blazers
Oil pans wet !! 2002 4x4 4dr. , gasket maybe?
Old Mar 7, 2018 | 01:32 PM
newguy's Avatar
Check the remote oil filter lines. common on these trucks
Old Mar 7, 2018 | 02:01 PM
thanks will do
Old Mar 7, 2018 | 07:17 PM
Seconding that. Get under there with some degreaser to clean it all up so you can find the origin of the leak.
Another culprit is the o-ring that seals the adapter between the aft-end of the oil lines and the engine block. I had mine blow out on my '92. When I replaced the lines on my 1999, replaced the o-ring and the gasket in the adapter while I was at it.
There are lots of threads here about replacing these lines and how to take your old ones and use better hoses and clamps.
This is my write up on my experience with replacing the lines.
https://blazerforum.com/forum/2nd-ge...-lt-4wd-95518/
Old Mar 7, 2018 | 07:21 PM
While you are under there, check all of the pan bolts. I have found loose pan bolts on 3 separate 2nd gen S-series 4.3L engines with the cast aluminum oil pan that caused an oil leak. Two of them looked like a rear main seal leak and the third was external in the area of the remote oil filter adapter. All 3 cases were remedied by tightening the bolts. My old '00 Bravada ended up working loose again at which time I removed each bolt, flushed the holes with cleaner, and used a medium strength loctite to keep them in place. I put 35k miles more onto it before selling it without a drop of oil lost.
Old Mar 9, 2018 | 12:25 AM
thanks for the help!!!
matthewp
May 7, 2014 08:40 AM
ComputerNerdBD
Mar 20, 2013 12:33 AM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
