Oil leaking
Yep. First was to replace gasket/o ring with help brand part. Replaced "line" gasket with little o rings from the same kit. Lasted for about ten miles before blowing out on of those little o rings.
Replaced little o rings with the right gasket, also help brand. This time those gaskets held, but the adapter block itself continued to leak a quart every 4-500 miles.
Got the dealer part and replaced the gasket/o ring. So far, so good!
The help (Dorman ?) part is also for some jeep application and comes with two different size o rings. They are almost identical. I might have put the wrong one in. I tried to make sure it was the same size as the one I took off, but maybe the original had dried out and shrunk, causing the original leak? When compared to the dealer o ring, it was noticeably thinner. I had already thrown away the other o ring that came in the kit, so I couldn't compare them.
I've got a 93 with a big time leak around the adapter bolted to the block. I cleaned everything and will try to purchase gasket tomorrow. If the job is as bad as the valve stem seal job a while back, well, here's my best Lurch impression....
Yes it's a tight spot with a 4x4. I measured and cut a "prop stick" before I started. After I had it jacked, supported, and safe. I made it so it would hold up the adaptor while I got a bolt in it. Really helped. I also ground the end of the bolts to a slight "bullet point". Hey, i'll try anything to help after the valve stem seal job...
latunguley
Nov 17, 2014 09:15 PM
LWegner
May 8, 2011 08:25 AM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
shooter2499
Feb 4, 2008 09:23 PM
