Oil Pan 2001 Blazer 4.3 vortec
Old Oct 12, 2013 | 06:53 PM
jg815's Avatar
jg815 is on a distinguished road
Default Oil Pan 2001 Blazer 4.3 vortec
I own a 2001 Blazer 4x4 with a 4.3 vortec.I have the engine up ,and supported,all oil pan bolts removed.I can't get the pan to drop from the block.It seems to be held in the rear of the pan by something.The front of the pan is loose enough to wiggle up and down with a pry bar,I can see the pan move at the rear,but wont drop from the block.Has anybody had one of these oil pans off?Its an aluminum pan,it almost acts like there's some kind of alignment pins,or small guide pins,maybe that are froze not allowing the pan to drop from the block I have checked multiple times to make sure all bolts are removed ,even the bolts through the bell housing.Anybody have any experience with these?
Old Oct 27, 2013 | 01:18 PM
geep's Avatar
geep is on a distinguished road
there are two bolts under covers in the back bought the size of a half dollars
Old Oct 28, 2013 | 05:29 AM
jg815's Avatar
Thanks,but I already found them.
latunguley
Nov 17, 2014 09:15 PM
ussexplorer
Mar 31, 2014 09:00 PM
Bluebeastblazer57
Aug 11, 2012 11:05 PM
blazerJim1701
Aug 28, 2009 11:50 PM
96blkblazer
Feb 26, 2009 04:29 PM
