p1870 code
Old May 11, 2014 | 10:04 AM
1960slickcraft's Avatar
1960slickcraft is on a distinguished road
Default p1870 code
I'm replacing the tcc valve since i'm getting the p1870 code and the symptoms that go with the code. I'm using the fitzall tcc valve.
Is it a bad idea to replace it without removing the valve body? I have instructions that say to bend the retaining clip to get the valve past the clip.
If i need to remove the valve body are there any surprises to expect? will any of the ball bearings fall out?
Old May 11, 2014 | 07:07 PM
screw it, i gotta get to work. A screw did the trick for now, it shifts a lot better.
knightryderx2
Feb 27, 2010 12:10 PM
robrote
15
Jan 7, 2010 07:37 AM
Nvidia78
Nov 5, 2009 07:25 PM
BABs
Aug 16, 2009 04:35 PM
luthers97blazer
Nov 12, 2008 09:18 PM
