pcv buzzes at idle
Old Dec 10, 2009 | 07:09 PM
rob f's Avatar
rob f is on a distinguished road
Default pcv buzzes at idle
2000 4.3 w 40'000 miles has rattling, buzzing noise at idle. Changed pcv, checked vacuum lines, no P codes wonder if anybody can help
Old Dec 10, 2009 | 07:28 PM
Check to see if your throttle or cruise cables are resting on the line from the PCV valve to the intake manifold.
Old Dec 10, 2009 | 08:02 PM
TFisher's Avatar
Banned
TFisher is on a distinguished road
I just replaced mine and the new one does the same thing. It's no problem, just a little annoying.
Regards,
Thomas
Old Jan 20, 2010 | 08:11 AM
rob f's Avatar
Thank you swartlkk - the throttle cable was transmitting vibration into the passenger compartment- 100% improvement. I,m L1 A8 but this one had me baffled.
rob f
Old Jan 20, 2010 | 08:14 AM
Glad to help!
Old Mar 6, 2010 | 09:22 PM
SWANNERZ's Avatar
SWANNERZ is on a distinguished road
OK I am willing to bet I have the same problem here with th PCV valve line rubbing, but what exactly is the remedy to fix the rubbing? It looks like a replacement for one earlier post worked. Thanks.
Old Mar 10, 2010 | 09:28 PM
SWANNERZ's Avatar
I guess what I mean is, do you have to zip tie the cables to prevent the rubbing in the future? Is replacing the PCV valve going to help at all (I've hear that if you take it out and it rattles when shaken it's fine)?
I also noticed when idling, if I move the gas pedal up from the bottom it changes the noise as well or revving the engine to a certain RPM.
Old Sep 19, 2010 | 08:33 AM
Lowfire's Avatar
Lowfire is on a distinguished road
I had a buzzing noise under the dash and it was the throttle cable touching the pcv line. A quick wire tie on the pcv line eliminated the noise. Thanks
Old Sep 22, 2010 | 02:19 PM
blazinloud's Avatar
im from Canada so i just wrapped it up with hockey tape
Mike F in Nebraska
Mar 14, 2014 09:28 PM
BlueDSM
Aug 11, 2010 05:05 PM
rob f
Dec 10, 2009 07:36 PM
4lowlife
Engine & Internal
Jun 28, 2006 10:35 PM
strongboy2005
Feb 17, 2006 04:44 PM
