possible lifter noise or just noisy motor?
Old Feb 20, 2008 | 09:42 PM
chevyman30571's Avatar
chevyman30571 is an unknown quantity at this point
Default possible lifter noise or just noisy motor?
I have noticed that when the rpm's get to around 2500-3000 rpms I hcan hear what sounds like a lifter noise. So i brought it back to the dealer i bought it from because it came with a warranty. The mechanic there said that this noise is due to the fact that the 4.3 vortec is a noisy engine. Also the noise is due to the fact that the 4.3 vortec has a solid lifter cam and lifters instead of being hydrolic. Is this true or do i have a big problem here? Could it also be the oil filter?
Old Feb 21, 2008 | 09:45 AM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Default RE: possible lifter noise or just noisy motor?
You do not have a solid lifter cam. Unless someone put one in there. You should have a hydrualic roller cam. Someone is blowing sunshine up your skirt.
What does your oil pressure look like?
Old Feb 21, 2008 | 10:16 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
it sounds like they just dont feel like looking into the problem........ if you just bought it i would def bring it back...i can hear it now the warranty runs out and your engine goes on vac leaving you to pay the bills...............
I just thought about this, did it make that noise after you plugged up the vaccuum port??? I saw you posted you found the missing link..
Old Feb 21, 2008 | 11:45 AM
the oil pressure when the motor is cold is around 60. Once it warms up it is 60 when driving and when stopped it is 40. I was thinking maybe it is th eoil filter that they put in. No the noise was always there. But if it was a lifter problem wouldn't it be there all the time and not just in the higher rpm range?
Old Feb 26, 2008 | 06:32 PM
strong blazer's Avatar
strong blazer is an unknown quantity at this point
sounds like theoil pump i am experiencing the same thing im trying to replace it as am typing
steve1969
Mar 10, 2013 11:48 AM
chelios#24
May 16, 2011 09:05 AM
mudnsno
Nov 15, 2009 05:38 PM
michigan_engineering
Jun 10, 2009 01:06 PM
glenmoore670
Feb 15, 2006 11:08 PM
