possible tranny/transfer case issue
Old 03-08-2009, 01:20 AM
crap98blazer's Avatar
crap98blazer is on a distinguished road
Exclamation possible tranny/transfer case issue
hello all! I'm hoping someone can help me, i have a 98 blazer 4x4 and im having an issue when when the truck reaches 50-55 mph, its as if the tranny downshifts and the rpms jump substantially. All with me maintaining the same amount of throttle which essentially slows me down unless i really press the gas... this problem resolves itself by be either staying below 50mph or above 65mph. i let the issue persist for about a week as i drive a very short distance every day.. no freeway.. but have now noticed that the trans has started slipping when trying to get into third... did i just screw the tranny?? thanks in advance
julian
Old 03-08-2009, 01:44 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Double posting is against the rules! I suggest reading (and following) the forum rules if you want people to help.
P.S. Your answer is actually floating around here already, try the search feature!
Old 03-08-2009, 09:47 AM
*Threads Merged*
Old 03-08-2009, 11:13 AM
sry guys, just thought id post it in engine and tranny as well as my gen model..
and i tried the seach and nothing depicted the problem exactly as i have..thanks for your help.
Old 03-08-2009, 01:22 PM
Sounds like your torque converter is unlocking, then locking back up with slight increases in throttle position.
How does your transmission fluid look/smell?
By posting in two separate forums with the exact same questions, you have effectively double posted. This is against forum rules. Having two posts will only serve to confuse the issue when you get responses in one or the other without everyone knowing about both threads...
Old 03-08-2009, 08:06 PM
Thanks kyle ill check the fluid tomorrow.. Although in the future i will not double post.
Flyfishen
06-18-2019 11:22 AM
heartlessmcfly
08-11-2011 08:28 PM
jhood17
01-18-2011 08:09 AM
Camo81
12-13-2010 11:16 AM
MagicMan
03-21-2008 12:55 AM
Quick Reply: possible tranny/transfer case issue
