pulling tranny off a blown motor
Old Oct 26, 2011 | 08:50 AM
1997 tricky1's Avatar
1997 tricky1 is on a distinguished road
Default pulling tranny off a blown motor
good day to all i have 1999 jimmy 4x4 automatic with a blown motor,wanted to pull the trans before motor but i cant turn the motor over to get to the torque converter bolts. i did however take out the oil pan bolts thinking i could remove the oil pan to try and free up whats siezed in there but seems like the pan dont want to break free,thanx for reading and may the snow fall soon
Old Oct 26, 2011 | 09:57 AM
chris015's Avatar
Hmm! thats a tricky one. Have you tried using a huge pipe etc and putting some "uhmp" in the crank bolt?
Old Oct 26, 2011 | 10:54 AM
pettyfog's Avatar
Bigger hammer. Seriously, you're not try to save the pan, are you?
Then loosen all the mains and rod bolts you can get to, and hope.
Old Oct 26, 2011 | 11:03 AM
ChevyBlazerChick's Avatar
Did you try to crank the motor over by hand? Like taking a 1/2 breaker bar with the correct socket and turning the bolt located on the front of the engine?
Or did you do that and still can't get it to move
Old Oct 26, 2011 | 06:00 PM
abig84's Avatar
if your just junking the engine, pull the trans/engine out as one unit. then remove the pan as you said you did and get in there with a torch and start cutting stuff, crankshaft, piston rods whatever makes the engine spin. been there done that. what a pain
Old Oct 27, 2011 | 10:25 AM
i tried turning it over by hand and its froze up,wonder if motor an trans will come out in one piece without pulling the front core support?i do need the oil pan,the knew long block does not come with a oil pan,but i could buy another one and just beat the hell out of it till it bust up
Old Oct 30, 2011 | 12:01 AM
rpeastep's Avatar
rpeastep is on a distinguished road
You can pull the transmission without disconnecting the torque converter from the flywheel. Then you can pull the engine with the torque converter still on the flywheel or you should be able to access the bolts without having to rotate the engine. If you can't reach them all just be careful with the torque converter when you pull the engine and you should be able to get to the bolts easily once you have the engine out.
limited edition 1
Jan 27, 2023 11:07 AM
badboy
Aug 3, 2010 12:05 AM
Slayton92
Jul 22, 2009 04:55 PM
desrt_rat
Engine & Internal
16
Sep 6, 2006 02:19 AM
ggwash21
Engine & Internal
Jun 17, 2006 02:08 AM
