Pushrod
Old Jun 16, 2011 | 07:49 AM
benthm7's Avatar
benthm7 is on a distinguished road
Default Pushrod
98 Chevy Blazer LS: two pushrods are tight with no back and turn forth; when tightening down the rocker arm the pushrod move down a little into its lifter set, then the rocker arm start moving down pushing valve spring down. The torque for the rocker arm is 20 lbs. Whats going on here
Old Jun 16, 2011 | 09:07 AM
The lifter is up on the profile of the cam. Nothing to worry too much about, but I would rotate the engine over until the lifters are on the came base circle (shortest part of the cam lobe) to do the final torque on the rockers.
98moneypit
Jul 23, 2014 01:46 PM
2bejustme
Jan 27, 2013 06:27 PM
